Ihost is a local server. Is it possible to turn on and off devices and scenes that are connected (created) to (on) this server from a remote location, for example with the ewelink application?
HI Steni.
You can do it using Tailscale . Available on Dockers. When Tailsacle is running on your IHOST, you can access from another device with an IP adress that Tailscale generates.
Except for Tailscale, other software would do the trick too, and it can run not only on iHost but any other devices in your LAN like FRP, Ngrok, and Cloudflare Tunnel.
