IHost Node Red HTTP In
Does the iHost allow Node Red to receive HTTP from over the local network? I am not receiving what I was expecting but may have the settings wrong at the other end.
There should be no restraint to node-red.
Check if your node-red run with host network.
If it dose, then receive HTTP should not be a problem.
Thanks. Next time I am on a big screen I will try again. It seems like there is a firewall blocking it somewhere. Will be good if it works as then the iHost will connect to the Seeed SenseCAP M2 Multiplatform M2 LoRaWAN hub as it has chirpstack V4 with a built in HTTP Push server.
