Yes tonight.
Is it that renaming is impossible on all devices, or is it only possible on specific devices.
Please submit a log through the feedback section on the iHost settings page.
The problem is when I connect via wifi to the wifi where the cameras are. Then the cameras crash.
I will connect to wifi and add onvif cameras. I turned it off.
Are the models of the cameras that cannot play normally the same? If it’s convenient, please submit logs through the problem feedback function on the iHost settings page, so that our technical team can better locate the root cause of the problem.
The cameras are from sonoff, herospeed and tp link. The same problem on each. The cameras work reliably.
I’ve shared the log file via iHost several times and had to resend it repeatedly. Apparently it’s not working for you.
We will resolve the issues that are troubling you. Could you please download the logs from the iHost settings page and submit them as an attachment to the feedback form? Thank you very much for your understanding.
I will send via ini link tem your feedback is not working, I shared the attachment and it did not come.
You can download logs from here: 1764098517037.tar.gz
Is the new Ihost really coming out this year? We were expecting its release during Black Friday. The old Ihost is now losing HA support.
