Hi. I recently switched to home assistant OS in my iHost. Everything is working as it should. However, the blue light is constantly flashing since the switch to Home Assistant. I tried turning it off and on, rebooting home assistant, but nothing has worked thus far. Any help will be greatly appreciated.
Kind Regards,
Sri.
If the home assistant has started, then everything is fine. The blue light should be constantly pulsating. Unless you change its configuration in the home assistant menu.
Okay. I found the HA add-on to control the lights. Thank you.
Which add-on did you install ? Flashing blue light is quite annoying. Can you share instructions?
I am getting following message when I try to add add-on and I couldn’t find any resource to fix it. Any Idea about how to fix it ?
‘StoreManager.add_repository’ blocked from execution, no supervisor internet connection
