How to Live With Sonoff and Home Assistant Without a Daily Headache (and Still Use the TRVZB)
eWeLink has been very busy lately: new firmware for NSPanel Pro and TRVZB, MQTT, “Home Assistant mode,” Matter, F‑Droid…
On paper it looks like a grand opening toward Home Assistant. In practice, it’s more like a polite bow followed by hitting your head on the table.
  1. The integrations exist… just not in the way HA users need
    Yes, I know the firmware odyssey is ongoing and changes keep rolling out - but from a Home Assistant user’s perspective, there’s no meaningful progress.
MQTT sends raw eWeLink JSON. Simple sensors behave, but TRVZB spits out broken entities and warnings because the payload doesn’t match HA’s expectations.
Matter looks promising until you realize the spec is limited and Sonoff exposes only a fraction of the device’s capabilities. HA receives a diet version of the TRVZB with half the calories missing.
SonoffLAN can’t keep up - changing DP formats without documenting anything doesn’t help.
  1. TRVZB is a perfect example of great hardware locked in a tiny cage
    The thermostat itself is excellent.
    The autonomous scheduler is genuinely useful and keeps working even if your network collapses.
The catch?
  • You can’t edit the scheduler anywhere except eWeLink,
  • Sonoff exposes zero scheduler-related DP via Zigbee, MQTT, or Matter,
  • and HA automations are just a prosthetic leg pretending to be the built‑in firmware logic.
TRVZB could have been brilliant - if only we were allowed to talk to it properly.
  1. Why does Sonoff keep disappointing?
Not because the ecosystem is closed. But because it’s closed and:
  • integrations are half‑finished,
  • APIs aren’t documented enough,
  • firmware updates break compatibility,
  • new features don’t fully work in any ecosystem.
One solid, well‑designed HA integration would solve 90% of this.
Most users would happily stay with eWeLink if things simply worked.
How to Live With Sonoff and HA Without Losing Your Mind (and Still Use TRVZB)?
  1. Use NSPanel Pro as your Zigbee coordinator
    It’s the only way to keep the full TRVZB scheduler and proper valve logic.
  2. Use eWeLink Cloud for configuration
    The scheduler is autonomous — and eWeLink is the only place where you can edit it.
  3. Use Home Assistant for higher‑level automation
    HA is great for logic and orchestration, but it won’t replace the TRVZB firmware.
  4. Treat MQTT as a data pipe, not a device integration
    The payload is incomplete, so don’t expect miracles.
  5. Ignore Matter until it grows up
    Right now it’s just another polite bow ending with a forehead‑to‑table moment
Note: This opinion is, of course, wildly exaggerated and not entirely fair — but that’s intentional. It’s meant to spark a tiny moment of reflection in the never‑ending firmware update marathon. And I’d genuinely love to hear whether other users feel the same way, or if I’m just yelling into the smart‑home void.
Let’s actually talk to each other, because asking for new features won’t magically fix the old, very real problems. So how about we treat this as a bit of New Year’s cleanup? And since the Chinese New Year doesn’t arrive until February, we’ve got a generous window — from January 1st to February 17th — to pretend we’re getting our act together.
Thanks for sharing your work. No offense intended, but let me offer a short, gently cynical summary :slight_smile:
Your “hacked” NSPanel Pro is, in practice, a mains‑powered DIY tablet.
  • If someone wants a tablet, there are entire aisles full of them.
  • If someone wants a hub, dedicated appliances exist for a reason.
And the timing doesn’t help: eWeLink has rolled out features in recent weeks that make this workaround feel even less practical. Why? In brief:
  • it doesn’t solve any of the actual Zigbee/TRVZB shortcomings (no schedules, no clusters, no diagnostics),
  • it removes the one real strength of the NSPanel Pro — local logic — without providing a meaningful replacement,
  • it converts a stable, plug‑and‑play device into a hobby project that now needs babysitting,
  • and a browser UI, however clever, doesn’t magically fix the underlying architecture.
So yes - it’s an interesting experiment, and certainly a fun technical detour.
But in terms of real‑world usefulness, it struggles to compete with ready‑made, supported solutions that simply… work OOB.
The hack doesn’t address any of the real issues of the NSPanel Pro, and that’s the key point.
  • It doesn’t improve Zigbee.
  • It doesn’t add cluster access.
  • It doesn’t add diagnostics.
  • It doesn’t provide a network map.
  • It doesn’t introduce push notifications.
  • It doesn’t fix TRVZB limitations.
  • It doesn’t enhance the API.
In other words: all the limitations that actually matter to users remain untouched. Your project removes the panel’s only real advantage: local logic.
Decided to remove my post as my opinion on what worked for me clearly isnt welcome. Best of luck with your thread.
There was really no need to remove it - your idea is an interesting solution, and someone might want to use it. My comments, although critical, were not meant to dismiss or undermine your work. I believe that, like many NSPanel Pro users, we all want to make this device as useful as possible. That’s why we discuss these things here on the forum.
Please restore your post. The eWeLink dev team follows our discussions, and every exchange can inspire new ideas.
Best regards.
Dear Jam3, Thank you for this posting and your attempt to shake up the almost capable Sonnoff/ewelink offering. I must start by saying that I have a fraction of you knowledge of these matters. I assume because of the use of the TRVZB you are wanting to provide elevated levels of control to a heating system. I share this passion and have been working towards this goal using sonnoff controls and IR electric heating panels (provides considerably better controlled zonal heating than a wet heating system can) and I am hitting what sounds like similar massively frustrating issues over thermal controls. The Thermo Plugin appears to be a partially developed piece of code and the thermo controls on the NS Panel Pro and NS Panel seem to be no better. I have pretty much given up.
