How can I install the correct version of node-red on my ihost?
Hey,
how can I install the correct version of node-red on my ihost?
In the Docker hub add-in search area I can only select unsupported version. There is no version for the ARMv7.
Have you tried this one: hassio-ihost-addon/hassio-ihost-node-red at master · iHost-Open-Source-Project/hassio-ihost-addon · GitHub
Thanks for your suggestion.
No,
because I don’t use home assistant
Hello, we sincerely apologize for the inconvenience caused. Regarding the Node‑RED upgrade issue, we would like to clarify the following:
Starting from version 5.0.0, the official Node‑RED Docker images no longer support the armv7 (32‑bit) architecture. Since iHost is based on the 32‑bit ARM architecture (armv7), it is not possible to directly upgrade to Node‑RED 5.0.0 or later versions.
Our technical team is already aware of both the installation and upgrade issues with Node‑RED on iHost and is urgently working on a fix. We will notify you as soon as the fix is completed. Thank you for your patience and understanding!
