Group Feature Control You Multiple Devices with One Tap
In our daily lives, we always need to do a lot of repetitive actions simultaneously. For example, When you are in party time, you need to adjust multiple lights to the same brightness. When you need to turn on all the lights on the first floor at the same time. When you go out, you need to turn off simultaneously all the lights in your home.
Have you found that there is such a feature in your eWeLink APP that your devices can be controlled and synchronized with one tap? It’s the Group Feature.
The group feature aim to make the same type of devices can be controlled and synchronized by just one tap. Without this feature, users could only be individually controlled through eWeLink app. Now you can create your group in setting page of your device. After the group is successfully created , it will be displayed on the homepage of the eWelink App. You can control or synchronize devices with one tap through the group
How to create Group
Step 1. Open the eWeLink APP and tap on the device to open Settings;
Up to now, all of the switchs,sockets and lights on eWeLink APP support the creation of groups. According to your needs, you can create unique groups that use devices such as the following. SONOFF BASICR2 SONOFF S55 SONOFF B02/05-B
Note: It should be noted that all devices in the group must be in the same home. Devices in different home, even if they are the same products, can’t be grouped.
Hi there, at present, users can’t group DUAL R3.
Suggest adding a manual scene, and setting all DUAL R3 as actions, then you can one-tap to activate this scene.
I just bougth 2x L3 Pro led strips, went to group but I dont see the option, any ideas?
I went and updated the app. I had older version. Now it seems that whenever I tap on one of my Led strips the app crashes. Uninstalled and installed but still the same. Any ideas for that?
Hi there, could you please provide the device ID for one of the four L3 Pro devices? With the device ID, I can check whether the L3 Pro is supported for the Device Group feature. Thank you!
Hi there, I apologize for the inconvenience. Unfortunately, I couldn’t find any detailed information about the mode L3-C-P. If it’s possible, could you please add the device to the eWeLink app and share the device ID with us? This will help our system to identify the device and provide more specific information.
Hi there, right now, grouping control is not available to L3 Pro. Actually, Sonoff team has added it to the roadmap. You can also bring your request to Sonoff team, which may speed up their implementation.
