Early Access Feedback: Floor Plan on eWeLink WEB (Members only)
Did you sign up for the early access? In case there might have been an issue during the process, you can send @Lottie your account details. She’ll add you to the early access list.
Thanks for sharing.
However, the current situation does not support virtual rooms. At present, rooms must be linked to a specific area on the floor plan, and devices within a room can only be displayed within that area. We may consider moving away from the concept of rooms in the future, but not at this stage.
Click Edit floor - Device - The bottom-right canvas icon
It may be a bit hidden. I’m trying to make it more obvious.
@lucacazzuoli Thank you for your patient sharing.
  1. That’s a really good idea. We’ll try to make it happen.
  2. Thank you for bringing this to our attention.
  1. Regarding the “hidden wall” effect for walls, would a low wall suffice? Or are you seeking a low wall that does not partition the area?
  1. As the current FloorPlan is a 2D overhead view, skylights do not appear essential to display. Or do you have other suggestions?
  2. I shall take your advice on board.
Thank you for your suggestion. We will consider this in the next version.
@Jpwrks
Thanks for your sharing.
We have a “Hide Walls” function. If you hide the walls after partitioning the area, would that meet your requirements?
Freely dragging devices into any area of the drawing is not difficult to implement. However, our goal is to achieve room-by-room zoning management for the home. Currently, we prefer not to break this design constraint.
In addition, the full version will support the ability to hide certain device icons. This feature is coming soon.
@wirkusmarcin83
Thank you for sharing.
If you could share the Floor Plan you’ve drawn, it might help us better understand the issue you’re encountering.
Dividing areas with interior walls is a supported feature. If it’s not working, it might be because the interior wall segments do not fully connect to the exterior walls. Could you check if the points of the interior walls align perfectly with the exterior walls?
Using grass texture to fill the garden area is a great idea—we’ll continue to optimize this.
Dragging room names to reposition them is not yet supported, but this feature is planned for the official release.
How can I assign a room name? nothing happens when I select a region and the manual does not describe it properly.
Change to Objects tab, and then select room area
I have done the registration and also send my account to Lottie.
Thanks a lot!!!
changing the angle of the furniture position in the map could also be entered as written
or fixed to a rotation of 45 degrees
@Lottie
I have over 130 different devices, I will add another 20 soon. Can I participate in the tests “Floor Plan”(?)
I now have a “Prime Plan” until March 1, 2027
Thank you very much for your support. But our Floor Plan feature has completed internal testing and has now officially launched. You’re welcome to start using it right away.
Tested by Advanced members, but available to Prime members only? Or also advanced members?
