iHost is capable of running a n8n server, which provides a node based workflow automation tool.
Docker image (ARMv7) here.
Docker image (Original) here.
Here is how:
Create two volumes named n8n-data and n8n-app.
In the add-on list, search for crazymax/n8n and add it to your local list.
After adding it, go to Docker Add-on List and click Run.
As Optional settings:
Port: 15678:5678
Network: bridge
Volumes:
Host volume: n8n-app / Add-on volume: /app
Host volume: n8n-data / Add-on volume: /data
Environment variables:
TZ=your preferable timezone (see TZ identifier here ) -
(Optional) On filebrowser/filebrowser add-on, map both volumes to a browse-able folder.
Volume n8n-data → /srv/n8n/data
Volume n8n-app → /srv/n8n/app
You should be able to access n8n editor on http://[ihost]:15678 (e.g. http://192.168.3.13:15678/).
Info: There’s a git not found message on log, but AFAIK it doesn’t interfere with running it.
That’s it. n8n should provide you a way of creating powerful workflow automation.
