How can I quickly get the temp emailed to me daily or hourly?
Any help or p[ointers would be appreciated.
You could use IFTTT, Home Assistant, Node-RED, etc. for that.
As I own an iHost and have Node-RED configured I would use Node-RED for that. Although I’m not sure whether the eWeLink CUBE add-on for Node-RED already supports temperature sensors. I just tested the SNZB-02D directly connected to the iHost and the Node-RED add-on supports providing the temperature, humidity, batterylevel and signal strength. Then you can connect any automation you want to it.
