Hi.
I’m trying out CAST for my unused tablet which I want to use as an HMI for my lights and switches etc. I’m mounting it on the wall between the lounge and kitchen so it central to everything.
I have a Bluetooth connection to an amp in lounge so I can play Spotify from the same tablet.
It would be nice if I didn’t have to leave CAST and instead had a widget for Spotify like the calendar and weather?
hi,
The music widget is in our plans and we are exploring how to integrate it into cast.
may need some time.
Thank you for the wonderful sharing of music, I also have a very good suggestion of music and mobile tonos de llamada for you
Would you please take a picture about the mounted tablet with CAST dashboard? how do you charging it?
I looked for a frame on AliExpress but didn’t see one I liked so I literally stuck it on with 2 small pads of 3M VHB tape.
Charging is just from a USB cable connection to a power socket with built in usb ports.
It’s probably not good for the battery but if I switch battery conservation mode on, it goes to sleep regularly and I have to log in , run chrome etc
