I’ve “reconnected” eWeLink to IfTTT and now my updated name for my eWeLink profile (“Gord”) is reflected in IfTTT (instead of older “No Nickname”) however under “Which 1-Channel Switch?” I still see “No options found”.
I’ve tried rebooting my iPhone also.
Should I be trying to attach photos? (If it is unclear what I’m trying to do here.)
Maybe someone else with a S40TPB could confirm the device can be used, and tell me which type of Trigger I should be choosing? I can’t imagine it being anything other than these 3… “1-Channel Plug turned on or off” / “Voltage goes above or below” / “Electric current goes above or below”.
Hi, there, sth tricky happened in the integration with IFTTT, need time to location the issue and fix it.
As for the nickname, it’s a new feature of IFTTT which is still in preview stages, and the power up or down triggers won’t be supported due to the chipset’s capabilities.
