The alarm feature is great but even set at max volume, it is really weak.
I need to be able to use the Alarm in the conditions of the scenes. This will allow to use a real siren
It would be an interesting solution to introduce the function of a voltage-free relay alarm output and an alarm input reacting to a short circuit to the ZBBridge…
Meanwhile, You can create scene to control siren
but you cannot trigger when the bridge is on alarm mode, you can only check sensors,
do you have a way to do that?
