Is it possible to control the iHost LED panel from CUBE OS?
I don’t think so. You can send audio files using the open API but I don’t remember controlling the lights. They’d probably need an RGB Array for each LED.
If you install HAOS on iHost, you can not only turn the LED panel on and off, but also change its color and brightness. However, this doesn’t seem to be available in CUBE OS.
