[iHost Language] - French-version F R A N Ç A I S E pour “iHost_2.14.0”
Traduction _iHost_FR_2.14.0(11874 lignes).json (404.4 KB) revisée
Traduction _iHost_FR_2.14.0(11874 lignes).zip (86.7 KB)
Hello @anlef, good afternoon!
Attention! the version 2.14.0 json file you posted has 11.530 lines, not 11.874 lines.
I translated version 2.14.0 into Catalan and the original English json file of this version for me has 11.858 lines.
I show it to you so that you can review it and if you like it, you can compare the number of lines.
Cordial greetings
Thanks for your message ; I updated a new “Traduction _iHost_FR_2.14.0(11874 lignes).json” file of 11874 lines. The .zip version is at 11874 lignes though.
Hello again
What I’m trying to tell you is that all translated files must have the same lines as the original English file of version 2.14.0.
According to my checks, I could be wrong, the file of version 2.14.0 should have 11,858 lines not 11,874 lines.
Cordial greetings
My French version 2.14.0 with 11,874 lines works very fine on my iHost “CUBE” and it is SECURE to use it. Maybe, you have lost some lines on your last translation work, who knows! Could you give me your link of you reference 2.14.0 English version, so I can double-check my work; maybe the original author as removed some features from the original .json, but I doubt it. I would remove code lines only if Sonoff authority asked me to.
