Here is my updated version for CATALAN. You can copy it and upload to your iHost (.JSON file).
I have detected that some texts cannot be translated because the file that can be downloaded does not allow it. Example: In the i-HOST configuration, everything related to the User Center.
Despite this, it works fine with eWeLink CUBE 2.1.0 (first version 1/8/2024).
A couple of days after the first download, I downloaded the English language template again and the surprising thing was that the file is larger (7110 lines).
Logical, since the new version incorporates improvements and more devices. Now everything related to the User Center is translated.
Therefore, I am publishing here the new version expanded with everything mentioned above and which should undoubtedly replace the previous one: version 1/8/2024.
