Does anyone know of Bluetooth speakers that work reliably? I have a JBL, a Sony, and a few others. In each case, I manage to connect them, but after a while (an hour or two), the iHOST indicates they’re connected when in fact the connection is lost, or the iHOST loops between connecting and then disconnecting. The AUTO-POWER option is disabled on the speakers.
All these speakers work fine with other devices, such as phones and tablets. Has anyone solved this problem in any other way?
Thanks for the tips.
i faced that issue with cubeos , tried several bluetooth dongles and didnt goes well , the only solution were to use usb sound card with aux to speaker
What sound card did you connect (type, model) to the iHOST USB port?
Generalplus Technology Inc. USB Audio Device , connected to cubeos not ihost , both suppose to be same
CUBE OS on iHOST is (I don’t think) “pure Linux,” but rather based on this technology, so (I don’t think) simply connecting the sound card to USB won’t help.
Maybe someone at eWelink knows more ![]()
its not cubeos on ihost , cubeos is separate os you can run at any mini pc and act like ihost
