Hi, does anyone know if is possible to use the SNZB thermometer with the TRVZB valve? In my case the actuator valve do not read the real temperature of the room due to furniture nearby and this cause malfunction and unexpected room temperature.
Thanks in advance
To use the SNZB thermometer with the TRVZB valve, setting up a smart scene is necessary. However, to achieve this requires hardware support. The Sonoff team is aware of this and it’s part of their future plans. Once the hardware devices undergo successful iteration and upgrade, you’ll be able to set up smart scenes for the SNZB thermometer and TRVZB valve in the eWeLink app. Your patience and understanding are greatly appreciated as we continue working to make this feature available.
Announce a competition for the most understanding and patient customer. The winner will take second place as there will not be enough patience to take the first ![]()
After all the update on the TRVZB was done to V1.2.1,
I was able to set the external Sonoff sensors SNZB-02D in the eWeLink app.
And it works also great in combination with TRVZB groups.
