SONOFF Dongle-M (Dongle Max) is a Zigbee/Thread adapter based on ESP32-D0WDR2 Wi-Fi SoC and EFR32MG24 2.4 GHz wireless SoC. It supports ethernet, Wi-Fi, and USB connectivity, allowing it to be deployed flexibly with open source smart home platforms.
With custom ESPHome firmware, ESP32 can be used as an ESPHome node while EFR32MG24 continues to provide Zigbee or Thread radio functionality. Flashing ESPHome firmware turns the Dongle-M’s ESP32 into a fully customizable ESPHome device.
Note: ESPHome firmware runs on ESP32 SoC of Dongle-M. It does not automatically replace the firmware of EFR32MG24 SoC.
WARNING: Building and running ESPHome firmware on Dongle-M is experimental and for DIY’ers only. ESPHome firmware is not necessarily more stable than Dongle-M’s official firmware. Please don’t proceed if you don’t know what ESPHome is and how it works.
1. GPIO Pinout
| Function | ESP32 GPIO | Direction | Notes |
| EFR32MG24 UART RX | GPIO13 | Input | Data from EFR32MG24 to ESP32 |
| EFR32MG24 UART TX | GPIO17 | Output | Data from ESP32 to EFR32MG24 |
| EFR32MG24 Reset | GPIO15 | Output | Active LOW |
| EFR32MG24 Bootloader | GPIO12 | Output | Used to enter radio bootloader mode |
| RGB LED - Red | GPIO4 | Output / PWM | LEDC PWM |
| RGB LED - Green | GPIO14 | Output / PWM | LEDC PWM |
| RGB LED - Blue | GPIO2 | Output / PWM | LEDC PWM |
| User Button | GPIO34 | Input | Active LOW |
| Ethernet MDC | GPIO23 | Output | IP101 PHY management clock |
| Ethernet MDIO | GPIO18 | I/O | IP101 PHY management data |
| Ethernet REF_CLK | GPIO0 | Input | External 50 MHz RMII clock |
| Ethernet PHY Reset / Power | GPIO5 | Output | Controls IP101 PHY |
2. Features
The following features are based on the example YAML configuration provided here. All parameters can be modified in ESPHome Device Builder to suit your needs.
2.1. Bluetooth Proxy
ESP32 runs esp32_ble_tracker and bluetooth_proxy, extending Bluetooth coverage of Home Assistant. This allows Home Assistant to monitor and control BLE devices such as BTHome sensors.
2.2. UART over TCP
ESPHome firmware exposes EFR32MG24 UART over TCP on port 6638. This is how ZHA and Zigbee2MQTT communicate with MG24 SoC.
2.3. MG24 Bootloader Mode
A switch in Home Assistant which can puts MG24 into bootloader mode, allowing firmware flashing over TCP, also on port 6638. Turn the switch off to reboot MG24 back to normal mode.
2.4. Physical Button
- Single click: Triggers a
single clickevent, and also turns on the fallback AP. - Double click: Triggers a
double clickevent. - Long press (5s): Triggers
long pressandlong releaseevents.
2.5. Status LED
- Blue blinking: No network connection.
- Solid blue: Network connected.
- Yellow blinking: A single click on the physical button.
3. Example YAML
esphome:
friendly_name: "Dongle Max"
includes:
- <esp_wifi.h>
# Initialize runtime state, reset the MG24 radio, and indicate booting.
on_boot:
- priority: 600
then:
- lambda: |-
id(button_long_active) = false;
id(mg24_bootloader_active) = false;
- switch.turn_off: radio_bootloader
- delay: 100ms
- switch.turn_on: radio_reset
- delay: 100ms
- switch.turn_off: radio_reset
- light.turn_on:
brightness: 100%
red: 0%
green: 0%
blue: 100%
effect: "Blink 500ms"
# Initialize connection status after ESPHome components are ready.
- priority: -100
then:
- text_sensor.template.publish:
state: "Disconnected"
- script.execute: update_status_led
# ESP32 hardware and framework configuration.
esp32:
variant: esp32
flash_size: 16MB
cpu_frequency: 240MHz
framework:
type: esp-idf
psram:
mode: quad
speed: 80MHz
logger:
api:
encryption:
key:
ota:
- platform: esphome
allow_partition_access: true
encryption:
external_components:
- source: github://SONOFF-Technologies/esphome-stream-server
# Prefer wired Ethernet when available, with Wi-Fi as fallback.
network:
priority:
- ethernet
- wifi
wifi:
# Optional: configure station-mode Wi-Fi credentials in secrets.yaml.
# ssid: !secret wifi_ssid
# password: !secret wifi_password
# Access point configuration used for local setup and recovery.
ap:
ssid: "Dongle-M_ESPHome"
ap_timeout: 0s
on_connect:
on_disconnect:
captive_portal:
# Ethernet PHY configuration.
# The PHY type, clock mode, and GPIO assignments are hardware-specific.
ethernet:
type: IP101
mdc_pin: GPIO23
mdio_pin: GPIO18
clk:
pin: GPIO0
mode: CLK_EXT_IN
phy_addr: 1
power_pin:
number: GPIO5
on_connect:
then:
on_disconnect:
then:
# Enable ESPHome Bluetooth Proxy for BLE device discovery and forwarding.
esp32_ble_tracker:
scan_parameters:
interval: 320ms
window: 160ms
active: true
bluetooth_proxy:
active: true
preferences:
flash_write_interval: 1s
# UART interface connected to the MG24 radio.
# The application baud rate can be changed at runtime below.
uart:
rx_pin: GPIO13
tx_pin: GPIO17
baud_rate: 115200
# Expose the MG24 UART over TCP.
stream_server:
- id: radio_stream_server
uart_id: radio_uart
port: 6638
buffer_size: 4096
# RGB status LED driven by three PWM channels.
output:
- platform: ledc
pin: GPIO4
frequency: 5000Hz
channel: 0
- platform: ledc
pin: GPIO14
frequency: 5000Hz
channel: 2
- platform: ledc
pin: GPIO2
frequency: 5000Hz
channel: 4
# Status LED indications:
# - Blinking blue: network disconnected
# - Solid blue: network connected
# - Blinking orange: temporary single-click indication
light:
- platform: rgb
icon: mdi:led-on
red: status_led_red
green: status_led_green
blue: status_led_blue
gamma_correct: 2.0
default_transition_length: 0s
flash_transition_length: 0s
restore_mode: ALWAYS_OFF
effects:
- pulse:
update_interval: 500ms
min_brightness: 0%
max_brightness: 100%
- pulse:
transition_length: 500ms
min_brightness: 0%
globals:
- id: button_long_active
type: bool
restore_value: no
initial_value: 'false'
- id: mg24_bootloader_active
type: bool
restore_value: no
event:
- platform: template
icon: mdi:gesture-tap-button
event_types:
- "single click"
- "double click"
- "long press"
- "long release"
binary_sensor:
- platform: stream_server
stream_server: radio_stream_server
connected:
internal: true
on_press:
state: "Connected"
on_release:
# Physical user button.
# Actions:
# - Single click: emit an event and enable the access point
# - Double click: emit a double-click event
# - Long press (5 s): emit a long-press event
# - Release after long press: emit a long-release event
- platform: gpio
pin:
number: GPIO34
mode:
input: true
inverted: true
filters:
- delayed_on_off: 20ms
on_press:
then:
- lambda: |-
- script.execute: button_long_press_detector
on_release:
then:
- script.stop: button_long_press_detector
- if:
condition:
lambda: |-
return id(button_long_active);
then:
- event.trigger:
event_type: "long release"
- lambda: |-
on_multi_click:
- timing:
- ON for 40ms to 800ms
- OFF for 40ms to 400ms
- OFF for at least 500ms
then:
- event.trigger:
event_type: "double click"
- timing:
then:
- event.trigger:
event_type: "single click"
- script.execute: force_ap_on
- script.execute: single_click_indicator
sensor:
- platform: wifi_signal
update_interval: 30s
entity_category: diagnostic
- platform: uptime
type: seconds
update_interval: 60s
text_sensor:
name: "UART over TCP"
icon: mdi:lan-connect
update_interval: never
switch:
# Internal MG24 reset control.
- platform: gpio
pin:
number: GPIO15
mode: OUTPUT
inverted: true
# Internal MG24 bootloader control.
- platform: gpio
pin:
number: GPIO12
mode: OUTPUT
inverted: false
# User-facing control for entering or leaving the MG24 bootloader.
name: "MG24 bootloader mode"
icon: mdi:memory
lambda: |-
return id(mg24_bootloader_active);
turn_on_action:
- script.execute: enter_radio_bootloader
turn_off_action:
- script.execute: reset_radio_to_app
# Runtime access point control.
# ESP-IDF Wi-Fi APIs are used here to enable or disable AP mode
# without restarting the device.
icon: mdi:access-point
lambda: |-
wifi_mode_t mode = WIFI_MODE_NULL;
const esp_err_t err = esp_wifi_get_mode(&mode);
if (err == ESP_ERR_WIFI_NOT_INIT) {
return {};
if (err != ESP_OK) {
ESP_LOGW("ap_control", "esp_wifi_get_mode failed: %s", esp_err_to_name(err));
return {};
return mode == WIFI_MODE_AP || mode == WIFI_MODE_APSTA;
turn_on_action:
turn_off_action:
- script.execute: force_ap_off
button:
icon: mdi:restart
on_press:
# Select the MG24 application baud rate.
# The selected value is persisted across restarts.
# Bootloader communication always uses 115200 baud.
select:
name: "MG24 baud rate"
icon: mdi:swap-horizontal
entity_category: config
options:
- "115200"
- "460800"
- "921600"
initial_option: "115200"
optimistic: true
restore_value: true
on_value:
- if:
condition:
lambda: |-
return !id(mg24_bootloader_active);
then:
- script.execute: apply_radio_app_baud_rate
script:
- id: button_long_press_detector
mode: restart
then:
- delay: 5s
- if:
condition:
binary_sensor.is_on: user_button
then:
- lambda: |-
id(button_long_active) = true;
- event.trigger:
event_type: "long press"
- id: update_status_led
mode: restart
then:
- if:
condition:
lambda: |-
return network::is_connected();
then:
- light.turn_on:
effect: none
- light.turn_on:
brightness: 100%
red: 0%
green: 0%
blue: 100%
else:
- light.turn_on:
brightness: 100%
red: 0%
green: 0%
blue: 100%
- id: single_click_indicator
mode: restart
then:
- light.turn_on:
brightness: 100%
red: 100%
green: 50%
blue: 0%
- delay: 10s
- id: force_ap_on
mode: restart
then:
- lambda: |-
wifi_mode_t current_mode = WIFI_MODE_NULL;
esp_err_t err = esp_wifi_get_mode(¤t_mode);
ESP_LOGE("ap_control", "esp_wifi_get_mode failed: %s", esp_err_to_name(err));
return;
wifi_mode_t target_mode = current_mode;
if (current_mode == WIFI_MODE_STA) {
target_mode = WIFI_MODE_APSTA;
} else if (current_mode == WIFI_MODE_NULL) {
target_mode = WIFI_MODE_AP;
if (target_mode != current_mode) {
err = esp_wifi_set_mode(target_mode);
ESP_LOGE("ap_control", "Enable AP failed: %s", esp_err_to_name(err));
return;
# Allow the Wi-Fi mode change to take effect before applying
# the AP configuration.
- delay: 100ms
- lambda: |-
ESP_LOGE("ap_control", "esp_wifi_get_mode failed after enabling AP: %s", esp_err_to_name(err));
return;
if (current_mode != WIFI_MODE_AP && current_mode != WIFI_MODE_APSTA) {
ESP_LOGE("ap_control", "AP mode is not active");
return;
const auto ap = id(wifi_network).get_ap();
const auto ssid = ap.get_ssid();
const auto password = ap.get_password();
wifi_config_t config = {};
const size_t ssid_len = std::min(ssid.size(), sizeof(config.ap.ssid));
std::memcpy(config.ap.ssid, ssid.c_str(), ssid_len);
config.ap.ssid_len = ssid_len;
const size_t password_len = std::min(password.size(), sizeof(config.ap.password) - 1);
if (password_len > 0) {
std::memcpy(config.ap.password, password.c_str(), password_len);
config.ap.password[password_len] = '\0';
config.ap.authmode = WIFI_AUTH_WPA2_PSK;
} else {
config.ap.authmode = WIFI_AUTH_OPEN;
config.ap.channel = ap.has_channel() ? ap.get_channel() : 1;
config.ap.ssid_hidden = ap.get_hidden() ? 1 : 0;
config.ap.max_connection = 5;
config.ap.beacon_interval = 100;
err = esp_wifi_set_config(WIFI_IF_AP, &config);
ESP_LOGE("ap_control", "esp_wifi_set_config(AP) failed: %s", esp_err_to_name(err));
return;
if (captive_portal::global_captive_portal != nullptr &&
!captive_portal::global_captive_portal->is_active()) {
captive_portal::global_captive_portal->start();
ESP_LOGI("ap_control", "Access Point enabled");
- id: force_ap_off
mode: restart
then:
- lambda: |-
return;
if (current_mode == WIFI_MODE_APSTA) {
err = esp_wifi_set_mode(WIFI_MODE_STA);
} else if (current_mode == WIFI_MODE_AP) {
err = esp_wifi_set_mode(WIFI_MODE_NULL);
} else {
captive_portal::global_captive_portal->end();
return;
ESP_LOGE("ap_control", "Disable AP failed: %s", esp_err_to_name(err));
return;
ESP_LOGI("ap_control", "Access Point disabled");
- id: apply_radio_app_baud_rate
mode: restart
then:
- lambda: |-
const auto option = id(radio_baud_rate).current_option();
uint32_t baud_rate = 115200;
if (option == "460800")
baud_rate = 460800;
else if (option == "921600")
baud_rate = 921600;
if (id(radio_uart).get_baud_rate() != baud_rate) {
id(radio_uart).flush();
id(radio_uart).set_baud_rate(baud_rate);
id(radio_uart).load_settings();
# Enter the MG24 bootloader.
# Bootloader communication always uses 115200 baud without
# changing the saved application baud rate.
- id: enter_radio_bootloader
mode: restart
then:
- lambda: |-
id(mg24_bootloader_active) = true;
if (id(radio_uart).get_baud_rate() != 115200) {
id(radio_uart).set_baud_rate(115200);
id(mg24_bootloader_switch).publish_state(true);
- delay: 100ms
- switch.turn_on: radio_bootloader
- delay: 100ms
- delay: 100ms
- delay: 500ms
# Reset the MG24 back into normal application mode and restore
# the configured application baud rate.
- id: reset_radio_to_app
mode: restart
then:
- delay: 100ms
- delay: 100ms
- delay: 500ms
- lambda: |-
id(mg24_bootloader_switch).publish_state(false);
Note 1: Please specify key under encryption of Native API component, and password under ap of WiFi component for security reasons.
Note 2: Specify ssid and password of WiFi component if Dongle-M is connected to your router through Wi-Fi.
Here is how Dongle-M looks in Home Assistant with ESPHome firmware:
4. Flashing Zigbee, Thread firmware to MG24 SoC
4.1. Using Dongle-M’s Web Console
Before flashing ESPHome to Dongle-M’s ESP32 SoC, you can use Dongle-M’s Web Console to flash Zigbee NCP, Zigbee Router, OpenThread RCP, Multiprotocol RCP, or even custom firmware to Dongle-M’s MG24 SoC.
4.2. Using Universal Silicon Labs Flasher
Universal Silicon Labs Flasher from Nabu Casa supports flashing firmware over TCP. Put Dongle-M’s MG24 SoC into bootloader mode, and then use command like the following to flash Zigbee or Thread firmware to MG24:
universal-silabs-flasher --device socket://192.168.4.71:6638 --probe-methods bootloader:115200 flash --firmware config/donglem-mg24/donglem_mg24_zigbee_stable_921600_9.1.0.gbl
# 192.168.4.71: the IP of your Dongle-M.
# config/donglem-mg24/donglem_mg24_zigbee_stable_921600_9.1.0.gbl: the local path to the firmware for MG24 SoC.
Note: Universal Silicon Labs Flasher also supports Writing IEEE address to Zigbee NCP firmware, which is normally needed if you are migrating your old Zigbee adapter to a new one.
