Control possibilities of NS Panel is very limited as you can not trigger or control thermostat settings via ewelink SCENES, even Amazon Alexa reports the NS Panel as a SWITCH device and not a climate control device.
The suggestion if to add SCENE capabilities to react or set thermostat (set auto / manual mode, turn thermostat on/off and set temperature setpoint).
Also to report to Amazon Alexa NS Panel as a climate control device (thermostat), so that you can interact via voice with the climate control capabilities.
If you are reading this and agree on these functionallities, please vote this up with your LIKE to raise visibility.
Thanks !
