I found the solution! if admin/admin is not working you need to look into the addon logs and see it printed there a temp password!
- Password: (printed in your console)
Note that from latest version Filebrowser does not accept lines 2 and 3. Runs correctly without.
I keep having permission denied with filebrowser.
cant create edit configuration.yaml or create zigbee2MQTT conf file ![]()
Since I posted 10 days ago there have been 2 new updates and as you posted before, you have to copy the password from the log, and also now if you change it must have a minimum of 12 characters.
Installation does not need, it seems, the database and config lines but I couldn’t edit files, so I had to delete /reinstall /remap my Node-red etc volumes. Now working OK again.
I am rebuild version v2.32.3 for IHost.
You can find it in Docker Hub: “el404/filebrowser-for-ihost”.
Everything works. You can find the password in the log.
Network: bridge
Port: 1234 80
/srv
HomeAssistant - /srv/HomeAssistant-files
zigbee2mqtt - /srv/zigbee2mqtt-files
mosquittoConfig - /srv/mosquittoConfig-files
