# ZBBridge-P direct end device limit
**URL:** <https://forum.ewelink.cc/t/zbbridge-p-direct-end-device-limit/27041>\
**Category:** Free discussion\
**Tags:** zigbee\
**Created:** [January 13, 2024, 5:41pm UTC](https://forum.ewelink.cc/t/zbbridge-p-direct-end-device-limit/27041 "2024-01-13T17:41:21Z")\
**Showing post:** 2
**Author:** ![morgan](https://dub1.discourse-cdn.com/flex005/user_avatar/forum.ewelink.cc/morgan/32/3184_2.png) [@morgan](https://forum.ewelink.cc/u/morgan)\
**Post date:** [January 13, 2024, 6:45pm UTC](https://forum.ewelink.cc/t/zbbridge-p-direct-end-device-limit/27041/2 "2024-01-13T18:45:14Z")
> [@HondaSkier](#):
> Do you have any opinions on this ?
_NOTE: ZB Bridge-P can connect 26 sub-devices directly (10 end devices + 16 routers, or 26 routers). If you want to connect to 128 sub-devices, routers are required, and one router-device can expand to connect 20-32 sub-devices._
_SONOFF Zigbee Bridge Pro can work with the devices below:_
_Router: ZBMINI smart switch,S40 Lite ZB smart plug, S31 Lite ZB smart plug, S26R2ZB smart plug_
_End Device: ZBMINI-L smart switch, SNZB-01 switch, SNZB-02 Temp. and Hum. sensor, SNZB-03 motion sensor, SNZB-04 door/window sensor_
> [@SonOff ZigBee Bridge Pro not adding more than 12 devices](https://forum.ewelink.cc/t/sonoff-zigbee-bridge-pro-not-adding-more-than-12-devices/16076/4):
> Found the following documentation from ITEAD product list. This is consistent with the behaviour I have seen. Without a Zigbee bridge added, its only 10 end devices. NOTE: ZB Bridge-P can connect 26 sub-devices directly (10 end devices + 16 routers, or 26 routers). If you want to connect to 128 sub-devices, routers are required, and one router-device can expand to connect 20-32 sub-devices.
_[View the full topic](https://forum.ewelink.cc/t/zbbridge-p-direct-end-device-limit/27041)._
