After setting up the wireless door sensor it works fine for about two days but after that it stops responding.
Only if I disconnect and reconnect the battery it works again. This happens on all wifi door sensors I have.
Model:DW2-wifi
It’s wired that reconnects the battery can make it work again,
Have looped this issue to our support team for further digging, will back to you if we have some clue.
Check whether the coating or outer layer of the battery is in contact with the metal clips, if so, it will cause the short-circuit of the battery and stop supplying power to the device and offline issue.
Dear i have this problem too
The sensor goes ofline severell times i trid reinstall but same problem
Too many ofline isues there is a huge network problem with this dw2
Br erik
Hi yitie
Yes Im aware of that, I already maked som fixing improvements. I also had one with soldiering problems…
I think you have an issue to keep cells in place, vhere there are some vibration…
Br. Erik
Hi yitie
In the 3 sensores where I have fixed the batteries they ort to be reinstall to the network for comming back online after several times they go ofline and I have to reset again.
Hi yitie
Now i tried to put new sensor instead of one who goes ofline.
Sensor goes ofline just after installation
It’s newer comes to upgrade. By putting new battery doesn’t help?
60mbps network !
After several attempts with new sensors I have now installed a new one at its place
It’s still online when I wrote this…
Br erik
Hi yitie
I think you have an app problem
I have some of yours relays they always worked 100% never had problems
Now in the last 14 days they several times go’s ofline
But first when i try to activate it by the pus button.
