āćRelease NotećeWeLink CUBE on iHost Version History
V2.10.0 [2026/01/30]
iHost V2.10.0 Now Officially Released!
This update introduces enhanced device control capabilities and expanded support for SONOFF devices, along with improvements to Matter Bridge integration and Zigbee stability.
Please take a moment to review the release notes before updating.
New Features:
- Added support for shutting down the device from the local web interface.
- Added Adaptive Mode for SONOFF TRVZB to maintain a more stable room temperature.
- Added support for the SONOFF MINI-ZBD intelligent dry contact module.
- Upgraded the Matter Bridge SDK to V1.5.0.
Optimizations:
- Optimized default gateway naming when pairing with SmartThings and Alexa via Matter Bridge.
- Optimized power-on state settings for third-party devices.
- Upgraded the Zigbee firmware to version 8.0.2 to improve connection stability.
- Upgraded the Z2M version to support more Zigbee sub-devices.
Bug Fixes:
- Fixed an issue where syncing the gateway to Alexa via Matter Bridge could fail.
- Fixed a timeout issue when adding ONVIF/RTSP cameras.
The new version is being rolled out gradually to different regions.
Please wait patiently for the rollout to receive the new version.
I donāt know what your update procedures are, but iHost doesnāt offer me anything, but I see in the channel log that it has been released.
My main Ihost isnāt reporting updates either.
However, the device, which I wasnāt using and was sitting in a closet, detected the updates immediately after turning it on.
I try to keep track of everything so I can keep track.
Iām curious to learn more about this!
Another important point: so far I only know iHost and the SmartThings HUBs that support SDK 1.5.
It would be interesting if iHost could export cameras by matter to other platforms!
Even if this isnāt available on iHost due to some technical limitation on their endāsomething I donāt think they haveāthe fact that CubeOS supports this before other platforms would be a significant advantage, putting them ahead of everyone else in the market!
For example, ZBBridge-U could also be a bridge since it shares similar hardware with iHost; it could have RTSP or ONVIF to be integrated into the eWelink ecosystem or exported as matter!
Hello, we sincerely apologize for any inconvenience caused. The new version is not yet fully rolled out; please wait a little longer. We will gradually expand the rollout. Thank you for your patience and understanding!
You have a bug in the previous version, I disconnected the zigbee motion sensor and CubeOS claims it is still available.
When will the update for CubeOS be available on your own host?
It became available here.
Hello, we sincerely apologize for the inconvenience caused. To help us locate and fix this issue, please provide the following information:
The specific model and device ID of your Zigbee human body sensor.
How did you disconnect the sensor (e.g., by directly removing the battery, or by removing it from iHost)?
What CubeOS firmware version were you using in your previous version?
If convenient, please submit feedback through the iHost local webpage and check the āUpload Logā option. We will analyze and fix it as soon as possible. Thank you for your cooperation!
1, Device SNZB-03P
2, I removed the battery and iHost did not register this change. It still told me that the device is online. Fw version in iHost 2.9.3.
Thereās a problem with the Matter Bridge in version 2.10.0.
The bridge occasionally goes offline. In the IHOST MATTER BRIDGE menu, pairing with SmartThings appears and disappears periodically. Iāll share the logs once Iāve run some tests.
I ran some tests. After deleting the virtual devices created in node-red.
The matter bridge Ihost began working correctly.
Iāll now monitor whether the bridge issue recurs.
Did you manage to update the other iHost too?
Neither one, I wonder what updates they will release that are not available to everyonee.
I just received 5 more iHosts! and all the updates are available!
Iāve been using them since yesterday without any problems! I just want to know what things Iāve raised!
Iām having problems with bridges connected to iHost, but I think this is a limitation of iHost itself! They havenāt worked much on the function to receive Matter bridges from other companies yet!
I believe this is a flaw in eWeLink; they donāt accept many things in Matter!
