What SONOFF devices are already supported by the NSPanel Pro?
NSPanel Pro Supported Devices List - SONOFF Official
Version Updates
V3.6.1(Nov. 7th, 2024)
New Updates:
Now you can create up to 10 Energy Dashboards for NSPanel Pro in eWeLink app (App version 5.11.0 and NSPanel Pro firmware version 3.6.1 or later are required).
Added support for Matter Light Sensor.
Predefined device names will now sync during Matter device setup for easier identification.
V3.6.0
V3.6.0(Oct. 22th, 2024)
New Updates:
- Expanded support for controlling eligible Wi-Fi devices via LAN and for syncing logs when Zigbee devices reconnect to the network.
V3.5.0
V3.5.0(Sept. 14th, 2024)
New Updates:
Control eligible Wi-Fi devices via LAN on NSPanel Pro. ( For specific devices list, please refer here: NSPanel Pro Supported Devices List )
Microphone muting is available during voice calls.
Support viewing real-time power data from POWCT on the screen.
Optimization:
Improved the display of device status on the home screen. It can display the current status of the human presence / Door/Window / water leak sensor.
The temperature range of the thermostat is adjusted to 4-40℃.
V3.4.0
V3.4.0(Aug. 13th, 2024)
New Updates:
Support SONOFF SNZB-05P Water Leak Sensor
Now you can change the text size in Reminder (Notepad).
Support disarming the alarm and resetting the device with a security code.
Added support for minimizing ongoing voice call to a floating bubble.
Optimization:
Optimized NSPanel Pro UI design and user experience. Support adjusting light color, brightness, and more; and controlling multi-channel switches on the home screen.
Optimized the UI and interaction of the device split screen, long press the device icon to enter the device control settings.
Optimized the temperature and humidity sensor icon, different font colors correspond to different temperatures or humidity.
Optimized the icons of motion sensor, water leak sensor and door/window sensor, and the icons will flash when the sensor is triggered.
Optimized the alarm on the NSPanel Pro, and you can view the ringtone type and repeat time.
V3.3.0
V3.3.0(July. 9th, 2024)
New Updates:
Support SONOFF Zigbee Smart Water Valve SWV.
Support Matter human presence sensor and Matter wireless switch.
Set the action device auto to on/off/keep status when disabling the thermostat.
The home screen widget can select the camera or timer. (APP requires V5.8 or above)
V3.2.0
V3.0.1
V3.0.0
V3.0.0(Mar. 15th, 2024)
New Updates:
New UI design. Support customizing the layouts and widgets of the home screen.
Devices and scenes can be set on the same extended screen.
Support two-way call with CAST App.
Support adding Matter Light Switch and Matter Color Temperature Light.
Boot animation updated.
V2.4.0
V2.3.0
V2.2.0
V2.2.0(Nov. 10th, 2023)
New Updates:
Support switching NSPanel Pro from Zigbee gateway mode to Zigbee router mode. Click ‘Device Settings–Pilot Features–Zigbee Mode’ in the APP to enable Zigbee router mode. After switching to a Zigbee router, you need to bind it with other gateways.
Multi-channel Matter switches and plugs added to NSPanel Pro support All ON and All OFF control.
Support setting SNZB-06P as a trigger device for smart security.
Note: The APP needs to be upgraded to V 5.1.0 (It’s expected to be available at the end of this month for iOS users).
V2.1.0
V2.1.0(Sept 26th, 2023)
New Updates:
Support SONOFF Zigbee Thermostatic Radiator Valve. You can switch on and off, switch between manual/automatic modes and adjust the target temperature on NSPanel Pro.
Optimize the screen swiping experience. It is more accurate when swiping down to enter settings and swiping left or right to switch screens.
Support GSM switch and socket equipment.
V2.0.0
V2.0.0(Sept 12th, 2023)
New Updates:
Supports as a Matter hub to add Matter-enabled devices to the eWeLink App. Currently supports switches and plugs.
Support Bluetooth connection to external devices such as speakers, and play music or alarm through external speakers.
Support synchronizing Philips lights to NSPanel Pro from the eWeLink APP.
ZBMINI-L and ZBMINIL2 can be selected as thermostat execution devices.
Optimization:
- Thermostat function optimization. Improved temperature control accuracy, the minimum adjustable unit is 0.5; added ‘+’ and ‘-’ buttons; optimized thermostat interface.
Note: Some new features require upgrading the APP to V 5.0 before they can be used.
V1.11.0
V1.10.0
V1.10.0(July 10th, 2023)
New Updates:
Support SONOFF TX Ultimate, you can control its on/off and ambient light mode on NSPanel Pro.
Security mode supports more types of triggering devices.
Support CAST pad. You can make voice calls with CAST pad through NSPanel Pro (CAST APP can be downloaded in the Android pad APP store).
RTSP camera can play real-time audio.
Update the weather icon.
Support connecting to WiFi without entering the password.
Shorten the top window height of Webpages.
The temperature unit switching in the weather forecast is synchronized with the temperature unit of the weather (Setting–Weather–Temp. Unit).
V1.9.0
V1.9.0(June 8th, 2023)
New Updates:
Added 11 new languages, namely Indonesian, Catalan, Danish, Croatian, Slovak, Finnish, Bulgarian, Hebrew, Arabic, Traditional Chinese, and Japanese. There are currently 32 languages available in NSPanel Pro.
Support SNZB-01P, SNZB-02P.
The OTA time of Zigbee sub-devices in NSPanel Pro is extended to 30 minutes.
Support control the Groups shared from the App in NSPanel Pro.
V1.8.0
V1.8.0(May 9th, 2023)
New Updates:
Guest Mode – After turning on the Guest Mode on the APP, you can only control the device on NSPanel Pro, and cannot perform other settings (such as adding devices, setting a timer, etc.). This feature requires eWeLink App to be updated to V4.32.0.
Unlock with Passcode – You can choose direct control or passcode control in the APP. After setting the passcode, you need to enter the correct passcode to use NSPanel Pro. This feature requires eWeLink App to be updated to V4.32.0.
Optimize the Firmware Update Mechanism – When a new firmware is detected, you can check the firmware download process through the download progress bar in About–Software Update.
Added S40TPA and S40TPB as thermostat executive devices.
V1.7.0
V1.7.0(April 12rd, 2023)
New Updates:
Support display Temp. & Humi. data from other temperature sources on the main screen.
Support always-on display – Set ‘Never’ Auto-Lock in ‘Settings-Display’.
Support Homebridge, allowing you to sync the Zigbee sub-devices in NSPanel Pro to Homebridge, and control them in the Home App.
Support Node-RED, allowing you to manage and control devices through “nodes” and “flows”.
Support switching between 24-hour and 12-hour formats.
Added six new languages: Afrikaans, Czech, Hungarian, Slovenian, Vietnamese, and Thai.
V1.6.0
V1.6.0(Mar 13rd, 2023)
New Updates:
Zigbee sub-devices support timer feature, and some Zigbee devices support OTA.
Support S31, POWR3, POW Elite, POW Origin, TH Elite, TH Origin as the execution device in the thermostat.
Thermostat can be set as the executive action in smart scene, including turning on/off the thermostat, switching manual/automatic mode.
Optimization:
Optimize the login steps, you can go to the Wi-Fi settings on the scan code page.
Modify the boot animation.
V1.5.4
V1.5.2
V1.5.1
V1.5.0
V1.5.0(Dec 10th, 2022)
New Updates:
Added Webpages function, which can save webpage links in the APP and access them on NSPanel Pro.
Added panel-to-panel voice call function, call another NSPanel Pro of the same account through NSPanel Pro at any time.
Support clicking the weather icon to check the weather forecast for the next 7 days.
Add execution actions in smart scene – setting the Security Mode and Screen Status in APP smart scene.
Support setting multi-screen device lists and scene lists, and name them individually.
Support viewing the energy consumption data of the past 7 days on Device Consumption.
V1.4.0
V1.4.0(Nov 8th, 2022)
New Updates:
Support voice calls to NSPanel Pro via eWeLink APP.
Support SONOFF NSPanel Smart Scene Wall Switch.
Support all models of SONOFF light strips.
Optimization:
Optimize RTSP camera screen display, the screen ratio can be set to 4:3 or 16:9.
The manual mode of the thermostat adds the function of locking the swipe bar, and the temperature cannot be changed after locking.
Optimize mDNS function.
V1.3.2
V1.3.2(Sept 29th, 2022)
New Updates:
Support two-way sync between NSPanel Pro and Home Assistant devices, you can sync Zigbee sub-devices from NSPanel Pro to HA, as well as sync lights and switches on HA to NSPanel Pro.
Support adding MINIR3 and POW Elite.
Devices shared from others will display the share icon.
When updating to a new version, the version information prompt will pop up.
V1.3.1
V1.3.1(Sept 16th, 2022)
New Updates:
Added the custom wallpaper function, which supports uploading pictures in the APP as the wallpaper of NSPanel Pro.
Added the Device Consumption function, you can view the weekly power consumption.
Support manual configuration, in the Screen Settings, you can choose whether to display the Smart Scenes, Thermostat, Device Consumption page on NSPanel Pro.
Optimization:
Optimized the thermostat function to support more temperature sources.
The group you set will display the group icon on the panel.
V1.3.0
V1.3.0(Aug 30th, 2022)
New Updates:
Support viewing Zigbee sensor temperature and humidity data for a day/week.
Compatible with YEELIGHT two-color, RGB, and five-color lights, you can sync the YEELIGHT lights added in eWeLink APP to NSPanel Pro.
Support SONOFF iPlug Wi-Fi Smart Plug – S40, you can check the devices power consumption recorded by S40.
Preview the volume while adjusting the system volume.
Added four new languages: German, Polish, Swedish, Ukrainian.
V1.2.1
V1.2.0
V1.2.0(July 30th, 2022)
New Updates:
Compatible with RTSP cameras.
Added “Theme”, you can change the wallpaper of NSPanel Pro.
Added “Timer” function, you can set a countdown with NSPanel Pro.
Support as the execution device in the scene, used as a doorbell.
Support adding TH10, TH16, TH Elite, TH Origin, DUALR3, DUALR3 Lite.
Optimization:
- Optimized the screen sliding experience.
