So in the eWeLink Home Assistant, some of my Sonoff S31 show a ethernet connection icon versus the wirelss connection icon. How do I correct this? Everything is fine on the phone app.
Which means that your device is LAN capable and this setting is enabled, you can disable the LAN mode via the APP’s device setting page.
More info, check this,
https://appcms.coolkit.cn/ewelink/encyclopedia/14654.html
Well I’m confused then isn’t the wireless Icon also meaning a network connection via a wireless LAN? All 8 of my Sonoff S31 show a wireless icon on the phone app (which is correct). However 4 of my Sonoff S31 show that wireless icon and 4 show a LAN connection which is wrong in the eWelink Home Assistant Add-On. All 8 have LAN control turned on (choices are On/Off) in the phone app for each device. There is also a Network indicator (On/Off). So I’m stuck, toggling/saving did not change the connection indicator.
Any one have an idea here on why the eWeLink add-on (version 1.3.1) for Home Assistant is doing this?
Bump -
