simultaneous control of humidity and temperature in automatic mode is needed. I made a heated mirror to eliminate fogging of the mirror. The mirror fogs up under two conditions: 1. when the temperature in the room is much lower than the used water (this happens in autumn and spring, when it is not advisable to use heating, but the air temperature has dropped significantly). 2 condition is the presence of high humidity. Currently in th elite it is not possible in “auto mode” to use both temperature and humidity as an “if” condition at the same time
