"If" or "time range" statements in Smart Scenes configuration
I have smart lights setup around the apartment and I’d like to gradually shift the light colour from blue when evening starts to yellow closer to night.
Each smart bulb is also attached to smart switch, so I can turn them on/off with the wall switch and remotely. But because of this, my bulbs are not always online.
Right now I can do it only setting a scheduled timer to step by step set bulb to required color for given time.
But it doesn’t work as expected because most of the time in my corridor lights are off.
If would be nice to have a check for time range in the smart scene triggers, so I can apply proper coluor based on time range when it switched on.
If I understand correctly, maybe try something like this…
When the device is turned on, the automatic scene responds and executes a manual scene that sets the desired device settings.
