i-HOST: Why Lost of assings of location at all devices
This is the third time, including today.
Every time this happens, without any apparent cause, we have to assign the location of over 100 devices one by one.
This is an incredible waste of time.
Thank you for your feedback. We apologize for any inconvenience this may have caused.
To help us locate the issue more quickly, please provide your iHost logs following the instructions below. Instructions on how to obtain the logs are provided in the attached guide. If the log file is too large to upload successfully, we recommend uploading it to Google Drive and sharing a link that does not require access approval, as shown in the attached image.
We appreciate your understanding and support.
i-HOST: Lost of assignations of all devices
Here you are the i-HOST log file.
Greetings
Missatge de Wenmiao Zhang <notifications@ewelinkforum.discoursemail.com> del dia dc., 2 de set. 2026 a les 13:11:
Hello @Adolfo ,
Thank you for your feedback. At the earliest point visible in the current logs, the room association for some devices was already empty. As a result, we cannot see the step where it changed from “bound” to “empty,” and there is no corresponding operation record, so we are currently unable to identify the root cause. This is likely because you have a large number of devices and the logs roll over quickly, meaning the time when the issue occurred has probably already been overwritten.
If you encounter this issue again in the future, we recommend exporting the logs immediately (to prevent them from being overwritten by continued operation) and letting us know what operations were performed before the issue occurred and approximately when, so that we can investigate further based on that information.
Hello @Miao,
I hope it doesn’t happen again but if it does I will try because it takes a lot of time when it happens.
The worst thing is that before my notification it had been repeated like twice more.
Greetings
