How to control or invert indicator LED on Legrand/Bticino K4003C Zigbee switch (deviatore)
Hi everyone,
I’ve successfully paired the Legrand/Bticino K4003C Zigbee switch (deviatore) with my Sonoff iHost.
The device works correctly for switching, but I’d like to know if it’s possible to control or invert the indicator LED behavior — for instance, to have the LED on when the connected light is off, and off when the light is on.
I’ve checked the available clusters and attributes in the Zigbee device page, but I couldn’t find any parameter related to the LED indicator.
Is there a way to change this via a command, a custom Zigbee attribute, or perhaps a firmware setting supported by Cube?
Any insight or workaround would be greatly appreciated.
Thanks in advance!
