Someone has tried pairing a Bosch thermostat, Bosch room thermostat II, I can’t find it in red.
On supported devices it indicates that it is compatible with ihost
Hello, is your issue that you are unable to add these two devices via the device addition function? If it’s convenient for you, could you download the latest logs on the settings page and submit them here as an attachment? Thank you for your understanding.
I’m leaving you the YouTube video of its installation; you can see that it needs a QR code. In Home Assistant you have that option, but if you don’t work with Home Assistant there’s no way to do it.
Hello, you want to add this device, but iHost doesn’t have a QR code scanning function, right? Please point out if my understanding is incorrect. Additionally, is the “supported device list” you mentioned the “Zigbee Device Support Status” function list in the iHost settings page? Is the model of your device RBSH-TRV0-ZB-EU or RBSH-TRV1-ZB-EU? Currently, we only support these two devices.
In the list of compatible devices, the Bosch thermostat at 220v or pilas, the two models are compatible. But to be able to add the QR code you have to send it to pair it, the code when it is scanned gives you a code that you would have to add to it to be able to link it. In the case of HA if you have this option but for ihost to connect devices there is no there, I give you an image to understand what it would be like in HA.
Nueva imagen de mapa de bits.bmp (2.0 MB)
Sorry, I understand your request. After verifying with the technical team, scanning a QR code to add devices is not currently supported. For these two device models, we will evaluate and resolve the inconsistency in their addition methods in a subsequent version. Thank you for your understanding.
