# Booting issues of "HA over iHost"
**URL:** <https://forum.ewelink.cc/t/booting-issues-of-ha-over-ihost/175506>\
**Category:** HA over iHost\
**Tags:** ihost\
**Created:** [May 22, 2025, 8:34am UTC](https://forum.ewelink.cc/t/booting-issues-of-ha-over-ihost/175506 "2025-05-22T08:34:21Z")\
**Showing post:** 70
**Author:** ![MichaelLearnsToCode](https://dub1.discourse-cdn.com/flex005/user_avatar/forum.ewelink.cc/michaellearnstocode/32/1668_2.png) [@MichaelLearnsToCode](https://forum.ewelink.cc/u/MichaelLearnsToCode)\
**Post date:** [May 28, 2025, 9:26am UTC](https://forum.ewelink.cc/t/booting-issues-of-ha-over-ihost/175506/70 "2025-05-28T09:26:51Z")
Here is a YouTube video showing how to flash HA over iHost image on TF card and boot iHost from TF card:
[![](https://europe1.discourse-cdn.com/flex005/uploads/ewelinkforum/original/2X/a/adc7f2bcd80e797c7cf7414f2805df1ea322cea3.jpeg "How to Run Home Assistant over SONOFF iHost") ](https://www.youtube.com/watch?v=MlspHKmrNdY)
_You need to press the `mute` button one or more times within 5 seconds after power on iHost_
If you are certain that you did press the right button at the right timing, then I suggest to verify the following 2 things:
1. boot into eWeLink CUBE OS, open CUBE dashboard, goto `Docker` page. You should see an alert `No TF card inserted`, then insert your TF card that flashed with HA over iHost image. If you see a notice `TF card inserted` then it means that specific TF card has no compatibility issue. Otherwise, that specific TF card is not recognized, and iHost can’t boot from it.
 ![eWeLink CUBE OS without TF card](https://europe1.discourse-cdn.com/flex005/uploads/ewelinkforum/original/2X/3/3a83f19713535824d82b6dfdb9571abfb9225ab0.png)
 ![eWeLink CUBE OS with TF card inserted](https://europe1.discourse-cdn.com/flex005/uploads/ewelinkforum/original/2X/d/d52c4e63556aec4e9a98fac05a947d198559c372.png)
1. on eWeLink CUBE OS, press the `mute` button to see whether the LED indicator of `mute` button can be turn on or off. If not, it means the `mute` button is dead, so it can not be used to change boot media (internal eMMC or TF card).
 ![Turn on mute button LED indicator](https://europe1.discourse-cdn.com/flex005/uploads/ewelinkforum/original/2X/b/b973d6ad90d350bb97d2c44623291b3f48b6c02f.jpeg)
 ![Turn off mute button LED indicator](https://europe1.discourse-cdn.com/flex005/uploads/ewelinkforum/original/2X/3/3d191efa146cd98a344d745dab25ad5129583247.jpeg)
Here is a short video showing boot failure on TF card. The side LED stripe changes from `Marquee Red` (about 3~4 seconds) to `Breading Blue` (less than 1 second) to `Breathing Red` (forever).
**By the way, could you take a short video about how you boot iHost and press the `mute` button?**
_[View the full topic](https://forum.ewelink.cc/t/booting-issues-of-ha-over-ihost/175506)._
